Anyone successfully disabled TRAC?
I have a 92 SC400 with TRAC. I want to disable it because I am running nitrous.
I don't want to remove it incase I ever sold the car and its good to have in the winter.
However, I will be doing some racing at the track this spring/summer so I'd like to disable it so its not coming back on everytime I turn the car off.
I repeat, I DON'T WANT TO HAVE TO PUSH IT OFF EVERY TIME I START THE CAR.
Has anyone successfully disasble there TRAC for racing?
Under the hood, on the pass side near the fender is the control unit. the black plastic cover pops off, it's held on by clips. Either unplug it (this will cause the TRAC light to stay on) or disconect the throttle cable which runs from the box to the throttle body. this will cause the trac light only to come on when the ecu sees that it isn't working.
hey was searching for some parts and found this, hope it helps
http://www.mvpmotorsports.com/Templa...210&SearchYN=N
(scroll down and look for HKS Traction Control Removal Kit for 1993-98 Supra Twin Turbo)
fst4dr91
10-09-07 06:13 AM
