steel braided clutch master line??
Should be able to get one easily.. just measure how long you need it (make sure there is enough slack of course), and figure out the end fittings. Then you could piece together on summit, or call a brakeline company such as goodrich ? and order.
I don't know if there's an aftermarket one available...but I can put you in touch with a guy that might make one for you, he made one for my car which has a very proprietary looking fitting where it bolts to the clutch slave.
thats the only problem right now is, i dont have the tool to measure the threads. i dont have an existing line because i pieced together my manual conversion. does anyone know the sizes i need from end to end?? thanks
