Automatic Soarer tranny into an Automatic SC300?
Old 03-01-06, 11:17 AM
Blk97SC300
Blk97SC300's Avatar
Default Automatic Soarer tranny into an Automatic SC300?
As the title says, could the automatic Soarer tranny simply be a direct swap with my stock sc300 automatic tranny? Not sure if it matters, but my car is a 1997. I will be NA-T within one month (everything is already ordered), and I don't want my drivetrain to die on me. I've heard the Soarer ATX is a bit stronger than the sc300 tranny, so I felt it would be a good alternative to keeping the stock tranny.
I did a search, but didn't come up with a definite response. I've heard the auto Soarer tranny is a direct swap with the auto sc300 tranny with no modding/fabricating required... is this true? Any help would be great. Thanks in advance,
-Allen
Old 03-03-06, 03:05 PM
Blk97SC300
Blk97SC300's Avatar
has anyone done a sc300 to soarer (automatic transmission) swap?
Old 03-03-06, 05:04 PM
atekt
atekt's Avatar
Just buy an Built tranny from BoostLogic....Its only 1800$
Old 03-03-06, 05:15 PM
VJ RC51
VJ RC51's Avatar
You can get soarer autos for 1-200 bux all day long thats why. U can do a dang TH700R4 swap cheaper then 1800 lol
Old 03-03-06, 07:28 PM
Blk97SC300
Blk97SC300's Avatar
After buying a Soarer Auto tranny for about $200 or so... what else is required to make it fit onto my sc300? Bellhousing? anything else need to be modded to make ti fit into my car? thanks guys,
-Allen
Old 03-04-06, 08:36 AM
silversprucesc3
silversprucesc3's Avatar
-Allen
Good question...... I'd like to know as well
Anybody with answers??
Old 03-04-06, 10:14 AM
Aristo300
Aristo300's Avatar
I know for a fact there is no "modification" needed on the driveshaft side, but I'm unsure about the bellhousing side.
Old 03-04-06, 11:20 AM
Blk97SC300
Blk97SC300's Avatar
ok, so the driveshaft side on the soarer atx tranny will bolt right up? thanks bud
Now all I need is some1 to confirm fitment of the bellhousing onto the block. Anyone know 100% whether or not the soarer tranny will bolt right up to an auto sc300?
-Allen
Old 03-05-06, 09:56 PM
Blk97SC300
Blk97SC300's Avatar
People talk about swapping sc300 trannies with Soarer trannies all the time... nobody has done it with an automatic??
ANY input would be great!
-Allen
Old 04-03-06, 01:43 PM
Blk97SC300
Blk97SC300's Avatar
It seems like the bellhousing and driveshaft side of the auto soarer tranny will bolt up to my sc300...
anybody know if the tranny cooler lines are the same, along with the wiring, and the shifter mechanism?
-Allen
Old 06-10-07, 10:34 AM
SuperiorSC
SuperiorSC's Avatar
if you can swap the usdm 5spd tranny and the jdm 5spd tranny without mods, why wouldnt one be able to the same with the auto's? im going to try it out this week and ill let everyone know.
Old 06-10-07, 10:38 AM
soarer479
soarer479's Avatar
bell housing is the same as well but the wiring will be different im pretty sure
Old 06-10-07, 11:01 AM
MJHSC400
MJHSC400's Avatar
Well-- fwiw-- from what I remember you can swap a 1J bottom end/block with a 2J and keep on truckin if your 1J goes bad, and you get an extra .5L --
That being said, I would think the trans would bolt to any 1J or 2J motor--
Old 06-10-07, 04:23 PM
Rising_Sun
Rising_Sun's Avatar
Mechanically the 1JZ soarer Auto will be a direct replacement for the 2JZ-GE. BUT most of the 1JZ imported to the US are pre-ODB2. So the wire harness and clips only fit Pre-94 SC300s. 95-97 clips are different(Such as Speed sensor) and 98+ 5sp Autos are electronic kick down controlled.
Old 06-11-07, 06:13 AM
sc250tt
sc250tt's Avatar
hey man i did it to my 94 sc300 and it worked perfect my 97 sc400 has a 95 soarer tranny
Quick Reply: Automatic Soarer tranny into an Automatic SC300?
