Just dyno'd the 1JZ!
Old 03-03-06, 06:30 PM
kaosman
kaosman's Avatar
Post Just dyno'd the 1JZ!
Just dyno'd the Lexus. Made 263 horsepower & 275 pound-feet of torque. Only modification was a "test" pipe.
One interesting note. I left the stock fuel pump in place, based on a calc I came up with a while back on fuel requirements for my 7s. Sure enough, the AFR was in the 10s at 5800 and above. Looks like the stock fuel pump is sufficient for the 1JZ. Should be good for more boost too, considering that high rpms are more taxing to an injector than boost. I'm not advocating a stock pump at 14 psi, but 12 should be safe. We'll find out in a little bit here.
Old 03-03-06, 06:41 PM
BigManne
BigManne's Avatar
looking good man
Old 03-03-06, 11:36 PM
Last5Spd
Last5Spd's Avatar
wow not bad for just a test pipe...
which one u got?
Old 03-03-06, 11:42 PM
rscott
rscott's Avatar
this was at 14 psi or stock boost?
Old 03-04-06, 12:03 AM
blacksc400
Car Chat Moderator
blacksc400's Avatar
wondering how much I am making with my FMIC. HKS BV, INtake, and straight 3' pipe!!
Old 03-04-06, 03:26 PM
nimit1234
nimit1234's Avatar
OKay im a newb, and I want to 1jz my 5spd.. Can I keep stock everything except the suspension and exhaust? or can I leave those 2 alone too?.. Let me know.. thanks
Old 03-04-06, 04:17 PM
VJ RC51
VJ RC51's Avatar
i made 265rwhp on stock 10psi boost, awesome how close we are
Old 03-04-06, 05:46 PM
atekt
atekt's Avatar
Right on!Good numbers!Any vids?
Old 03-04-06, 06:02 PM
onebadshot
onebadshot's Avatar
I'm new to this board and I can see how you guys get tired of this question......... nimit please use the search. I have been looking at doing this swap for over a month and I still havn't covered all the info out there on it.
As for the dyno im so excited considering a stock RX-7 only makes about 250hp and your really pushing your luck on a stock 13b at 14psi. Also is there any tuning done on the dyno on the stock 1jz?
Old 03-04-06, 06:13 PM
STRONG SC
STRONG SC's Avatar
damn nice numbers!! let us know w/ more mods1
Old 03-05-06, 09:05 PM
kaosman
kaosman's Avatar
The "test pipe" was a one-off pipe made by a friend. Those numbers are at stock boost. I don't have any vids yet, but as soon as I get a new battery for my camcorder, I'll get some up.
Old 03-05-06, 10:34 PM
Arizona
Arizona's Avatar
Yes and Yes? your stock exhaust will bolt up to the 1jz and what does suspension have to with a motor swap
Old 03-06-06, 12:26 AM
blacksc400
Car Chat Moderator
blacksc400's Avatar
for the swap, you can keep the exhaust and suspension stock and vhange evrything else.
Old 03-06-06, 09:33 AM
VJ RC51
VJ RC51's Avatar
A 1JZ any mods on stock cams seems to top out around 320ish rwhp on any boost level. Add some aftermarket cams and ppl seem to get around the 380 mark.
Old 03-06-06, 09:56 AM
indypwr
indypwr's Avatar
nice numbers......i wonder how many hp mine is putting out..
i am assumming close to 350 with fmic, colder plugs and EBC..
Quick Reply: Just dyno'd the 1JZ!
