Neutral Start Switch and Clutch Start Switch locations?
I am looking for the location of these two items. I am still trying to figure out how to get my just recently |[ Auto to Manual ]| converted 93SC300 to start. From what I have read on a couple of forums and threads I am supposed to find the Clutch Start Switch and bridge it so that I dont have to use the clutch to start the car. However they failed to mention the location. I have a couple of diagrams that were given to me but am still confused as to where the location of each of those switches are. I am using the Auto Harness and M/T ECU just incase that makes a difference.
Link To Larger Version
There isn't a neutral safety switch on the manual, just the clutch switch. If you're using the manual wire harness, the key is supplying 12 volts to pin 8 of the two-row gray body connector down by the ECU. This wire will be black, and it goes straight to the starter relay by the battery.
