What to do about the 1 jz fule cut?
Wow, so many answers..... That sucks!
I heard the HKS FCD will alow my car to run as it should...
Please, any help is welcome...
im running an HKS BCC. If your cheap a simple $10 bleed valve will solve your problem too. Works just as good as an electronic version. You can also use a zenier diode. Theres a few ways to get around it. I got my boost cut controller for free, so that was my route.
Originally Posted by SoarerJzz3
Get a boost cut controller instead.
I have all the boost I need, but I top out as I start to get into 4th... So I take it an HKS FCD will work???
Originally Posted by aliga
get a 2jz na-t
Thanks for the slick reply, I'll pass on the 2J unless there is a GTE at the end...
what he said... as i was reading i was thinking the same thing... sooooo,
call titan and ask about the speed cut defencer that works for the 1J in an SC... they have sold a few. i dont think they are that expensive either.
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
i know im really late replying to this post.. but its sounds to me like yer hitting the speed limiter not boost cut.... u said "i couldnt even max out 4th gear"
that has nothing to do w/ boost....
i have a stock 1j w/ a boost controller (which is off) so its running on stock boost, and w/ my speed cut remover (pilot) the car hits 180 and keeps going... so anyway, while a boost controller would be nice, i HIGHLY doubt its the fix for yer problem.... i mean MAYBE if yer getting boost creep that could be it... where is your boost at when the cut comes in... and is it a bog/lick missfire.... or does the car just hit a wall
bog/misfire is what my car does when i hit boost cut @ .9bar...
hit a wall... is what my car did when i didnt have my speed cut
anyway sorry for the long post... but try that
just realized dewsc300 already said speedcut haha...oh well
