5-speed swap driveshaft W58??
Old 03-10-06, 08:59 PM
prjctSC300
prjctSC300's Avatar
Default 5-speed swap driveshaft W58??
im in the process of finishing up my 5-speed swap and came accross a driveshaft problem. do i need a 5-speed driveshaft for my swap?? im still using the stock auto diff. the stock auto driveshaft is a few inches too short. my car is a 92 sc3 and i believe the tranny is a 93 W58
Old 03-11-06, 07:22 AM
motorheaddown
motorheaddown's Avatar
The chances of the auto DS working with the W58 are about zero which means you'll also need the 5-speed diff and DS.
What ECU and harness do you have?
-scott
Old 03-11-06, 09:47 AM
prjctSC300
prjctSC300's Avatar
i am using the auto ecu and wiring harness? does it make any difference?? i have read that the auto would work with the 5-speed trans w/o any problems.
is it possible to get s spacer made or lengthen the auto driveshaft?? would my gearing be all messed up if i stick with the auto diff??
i believe jspec is running a auto driveshaft and auto diff w/ the w58 trans
Old 03-11-06, 02:53 PM
JspecSC3
JspecSC3's Avatar
Yes indeed. Im using my AUTO differential on my AUTO driveshaft on my MANUAL W58. It was a huge shocker when I found out that my 5speed driveshaft didnt fit. The first section of the auto and manual driveshaft are the same. The second half that goes into the differential are different lengths. After I had completed the swap I made a post about this little surprise. The answers I was recieving were that the AUTO differential is longer than the 5speed Differential.
Old 03-11-06, 06:15 PM
prjctSC300
prjctSC300's Avatar
damn, bro you got lucky somehow.
Old 03-11-06, 07:43 PM
jayzsun
jayzsun's Avatar
jspec, what year w58 did you install? was it from a 95 and up? they are longer than the 92-94 w58 trannys which maybe why your driveshaft lined up?
Old 03-11-06, 10:42 PM
JspecSC3
JspecSC3's Avatar
The W58 came off of a 96 Supra. Someone told me that the AUTO pumpkin on our SCs are also longer than the Manual ones. So if I have a longer W58 and longer AUTO pumpkin, that would leave me with a perfect fitting AUTO driveshaft. Ok I understand now.
Now for prjctSC300, would the 5speed driveshaft fit with his W58 and AUTO pumpkin? Or would he have to get the Manual pumpkin to make it fit?
Old 03-14-06, 10:40 AM
prjctSC300
prjctSC300's Avatar
does anybody know if the 5speed driveshaft would fit the W58 and auto diff??
Old 03-14-06, 04:40 PM
ConSynX
ConSynX's Avatar
Slammer will be able to tell ya the answer to that in a bit, he bought my w58 stuff.
Old 03-14-06, 11:24 PM
prjctSC300
prjctSC300's Avatar
is he using the auto diff also or manual diff??
Old 03-15-06, 10:01 AM
JspecSC3
JspecSC3's Avatar
Ask him to test fit the parts for us when he is near completion. And then have him post in this thread. I know prjctSC300 is near completion also and he is just waiting for this one answer to complete his project.
Also, since he is using your parts, What year is the tranny from and what year SC is it going into?
Old 03-15-06, 01:42 PM
ConSynX
ConSynX's Avatar
93 into a 94
Old 03-15-06, 01:47 PM
slamdawg54
slamdawg54's Avatar
hey all, im "slammer" the tranny is from a 93 sc going into my 94
right now i am waiting for a clutch until i can throw the tranny on to see what fits, i wont have this completed until probably this weekend since the clutch is due on friday.
as of now my plans are to use the auto diff, and i have the option of using a manual driveshaft or auto DS.
i will post the results asap, any questions, you can IM me at slamdawg543.
Thank you.
Old 03-15-06, 01:53 PM
JspecSC3
JspecSC3's Avatar
Yay!!
Old 03-15-06, 01:55 PM
prjctSC300
prjctSC300's Avatar
cool, keep us updated with the progress.
Quick Reply: 5-speed swap driveshaft W58??
