Please help with easy question... 1JZ wiring
I can't find this anywhere... someone please help me get my car on the road!
My wiring harness was complete from the ECU side... we extended all of the wires and it's good to go. However, the fusebox side is cut and we have no idea where the wires go. Does anyone have pictures of this part of their 1jz harness so I can get an idea of what it's supposed to look like? More importantly, does anyone know where I can find a wiring diagram for this?
My friend says some problems in particular are the horn is wired into the SC wiring harness, but not the 1JZ.... but that's not a big deal since it can be wired separately. However, we can not seem to find the ignition module wiring.
THANKS
THANKS
here you go man, i think this is everything you need for a diagrams http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/
Awesome link
Thanks for the posts guys! Your website has a TON of info on everything for the Soarer... great resource. I couldn't find any wiring diagrams for the wiring harness though, other than one of ECU pinouts? Are they located in one of the larger files that I can't open for some reason?
VJ RC51 - If you have time pictures would be great! Even if I do find the wiring diagrams I need, the pictures will still be very helpful to verify everything looks as it should.
Thanks again guys!!
Thanks again guys!!
My friend that is helping with the swap said that the majority of the wires we don't have look like they are supposed to go to an ignition module... since the soarer has coil packs and the SC300 has a distributor... was one supposed to come with the swap? I don't recall anyone here talking about an ignition module... what should I do!? lol
That's not what I wanted to hear :-(
Do the Supra guys still get a 1JZ ignitor or do their 7mgte ignitors work?
Here is the wiring harness on my car that is cut... does can anyone tell me where the connectors go?!
![](https://www.clublexus.com/gallery/data/500/scan.jpg)
B.Diddy
Performance & Maintenance
06-12-12 07:51 AM
