im gonna try putting on the sc300 ge brackets on the 1jz ...it seems as though they are different and a tad bit smaller...maybe it will help my situation..
supra na and supra tt have the same mounts.......ITs the Bracket that different........I think ima try to use the sc300 bracket to see if it makes a difference..ill keep u guys posted...DO you know if i can use the Sc300ge Brackets with the mkiv mount?
SC300 brackets will not work. At least on my 92 it didn't. I doubt there is a change in years but it could be possible. You will need the "short" supra mounts. Supra mounts with Supra brackets or SC300 mounts with SC300 brakets.
i put the motor in this weekend using hte supra mount si mentioned that are $55 each. don't know about any clearance issues since i'm still in process of swapping, but it all looks fine.
Do you have a soarer or supra 1jz?Im using the supra tt mounts.......and the ge brackets...ima see if i can get a hold of the tt brackets...the short ones...whats the combination u used
i have soarer 1jz, and using 1jz brackets
if you are already using your 2jz-ge brackets, and your 1jz-gte brackets didn't work either, wow...i really don't know what to say.
