What are my options for upgrading injectors
use the usdm sets since they are more readily available. you will have to wire in resistors, or a resistor pack so you dont fry the ecu since the jdm models runhigh impedence. either way of going you will need to add the resistors for anything over 550cc (atleast thats what i think is the highest flow for high impedence injectors). i think club na-t has the wiring guide on how to wire the resistors in. good luck and only buy low impedence if you plan on anything over 400 hp
Originally Posted by VGnomore
What are my options for upgrading injectors in a full jdm 2jz-gte? ? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Wondering what your h.p goal is, the usdm set up is quite capable of handling bpu +++ twins and hp into the 400's. Much above that you are going to need upgrade to much more then injectors.
Originally Posted by turbodude
550cc to be safe..
The 550's are a much better choice, why have anything running 9/10ths, particularly when it comes to fuel supply.
97-SC300
Performance & Maintenance
24
11-04-15 08:50 AM
