2JZ-GTE oil pan
I already did a search, and I couldn't find the exact info I needed.
I'm swapping a 2J from an Aristo into my '93 SC300. I know I need to change the oil pan off the Aristo motor. I know I can use the stock oil pan from my SC or from a Supra. I would have to modify the stock oil pan off my SC though to accomidate the oil return line. Here is my question though, if I get one off a Supra, do I need to get an NA or turbo oil pan? The NA oil pan would be the same as the one from my SC, correct? If I get one off a turbo model, will the oil return fitting be on the proper side? If someone coild clear this up for me, it would be greatly appreciated
Thanks!
Also, for my exhaust. Would I need to make a completely custom exhaust, or can I take one made for a Supra TT and use it on my SC? I know I will need to modify an exhaust made for a Supra. But what exactly needs to be done to it?
Thanks!
2jz02
07-23-08 11:25 AM
