2JZ-GTE Swap Questions
this should get you started
See 2nd post in this thread
https://www.clublexus.com/forums/sho...ight=quikturbo
ok, first of all... why do you say the 2.5L sti motor doesnt have any RnD behind it?
weight of the STi's GC or GD could be more or less, they have a lot of different models.
First, thanks the referral towards that thread with the spreadsheet, that helped alot.
Secondly, what is with the no RnD behind the EJ257? While Subaru spent more time with the EJ207, the EJ257 is an excellent motor but you can not compare it to the 10+ year old 2JZ-GTE and 4G63 because it simply has not been out long enough for the aftermarket to take advanatge of its true potential.
The 06 STI weighs a tad bit over 3300, it is certaintly no light weight but damn does it handle well.
Originally Posted by NyanaDream
6. The sc300/soarer weighs around 3500lbs. with roughly a 70/30 F/R weight distribution. The GC STi is around 3000lbs. and the GD STi is around 3200lbs., both at a 58/42 F/R weight distribution AND 4WD. You will not be able to feasibly accomplish this goal.
EDITED FOR BEAN: I got my info from TIF and Wikipedia. I stand by my facts, because they are backed up by informational sources. All of them correct and non-biased.
nope. jzz31 weight distribution - 54.5/45.5%
WHAT? do you understand how long the 4g has been out for? its already understood to be one of the greatest motors of all time. what a bad statement that is.
^Saying it like this it is an accurate statement, the EJ257 has been out 3 years and is almost reaching the levels the 4G63 took 10 years of existence to accomplish.
Moving SC Threads
i like mine
with real coilovers, big sway's & properly corner weighted, you can get the
old girl to turn quite well. i havent tried stalking a sti on the twisty's yet, but
i'll let you know how i make out.
if she wont run an 11 w/ my lame reaction time i'll give it to you.
DO IT & kick that subby to the curb.
john
john
