update on my 1jz....
Old 03-28-06, 04:31 AM
lpolo69
lpolo69's Avatar
Default update on my 1jz....
Well here are some pics i took of this last weekends progress.....Only thing now is my stupid mounting situation....... idiot brackets.......My t70 setup ....50mm hks wastegate......
Old 03-28-06, 05:45 PM
atekt
atekt's Avatar
More info please!Very interested in more about your setup?
Old 03-28-06, 06:02 PM
ConSynX
ConSynX's Avatar
Old 03-28-06, 06:08 PM
2.5tsoarer
2.5tsoarer's Avatar
Default wow
wow ebay spe!cal !!! good lux w!t that !
Old 03-28-06, 06:59 PM
atekt
atekt's Avatar
Is it really?
Old 03-28-06, 10:39 PM
lpolo69
lpolo69's Avatar
no its not its an ebay kit mp t70 with custom wheel...and custom mani wit custom 3inch dp..
only the 50mm hks wastegate was purchased on ebay
Old 03-29-06, 08:21 AM
VJ RC51
VJ RC51's Avatar
sick ***... i wanna see no less then 500rwhp
Old 03-29-06, 02:46 PM
2.5tsoarer
2.5tsoarer's Avatar
if its not ebay , take a pic of the label on the turbo!
if it was a custom manifold, wouldnt you have used a t3 flange when it was made instead of the t4 then welded a t3 to it
Old 03-29-06, 03:20 PM
5spdSC300
5spdSC300's Avatar
What are the specs on the turbo?
Old 03-30-06, 11:53 AM
lpolo69
lpolo69's Avatar
sure ill take a pic of the turbo this weekend ill also take pics of the new compressor wheel...gosh...................and its a 2jz manfold...when i meant custom i meant i had to weld the t3 flange onto it and cut the wastegate and reweld alot of things....Also port spacing on the 2jz manoi to make it work on the 1jz head..
Old 03-30-06, 11:56 AM
VJ RC51
VJ RC51's Avatar
you've been called out. I dont see much hp with at setup at all. Nothing more then what stock twins can do. That turbo looks ebay special. I seen a setup like that on a 1JZ mk3, made 275rwhp on 18psi.
GT35 or GT40 are the ticket, or anything very similar from SP, Precision, etc..
Old 03-30-06, 12:00 PM
lpolo69
lpolo69's Avatar
below are specs on the turbo..
T-70 - 2.720" / 3.850"
Old 03-30-06, 12:01 PM
lpolo69
lpolo69's Avatar
i dont have to proove anything to no one the numbers will show it once its done.. ONly thing is i might need a lil shot to get that turbo to spool up......................or swap the 3.0 block later for the additional .5 of displacement..
plex
1UZFE/2JZGTE
plex's Avatar
Dag yall kinda harsh but then again it's CL's most popular 1jz expert VJ RC51 involved once again.........he knows it all and everybody else knows nothing.. .......good luck with your setup lpolo69 keep us posted.
Old 03-30-06, 12:26 PM
2.5tsoarer
2.5tsoarer's Avatar
Ill post up Pictures of my GT35R set up Im installing in my car this weekend. Also installing 2JZ cams , cam gears, 2JZ 550's, resistor pack, on Greddy manifold and Wastegate.
The turbine housing on that set up looks like 1.0 or .83 . You can eat a sandwich while you wait for boost
Quick Reply: update on my 1jz....
