Is it hard to change timing belt?!?
how hard is it to change the timing belt and fan belt? thinkin about doing it myself
anyone that knows how to do it im willing to pay for a fair price in So Cali. also do tensioners and bolts need to be changed as well?
takes about an hour. Remove fan, rad, covers. line up crank pull to Tdc on the bottom cover, and make sure the cam marks line up with the marks behind the gears. Use a 3/4in (not 1/2in) impact gun to remove the crank bolt if its never been off. A 500FTlb 1/2in wont budge it if it was never off. Use a puller to get the crank pully off. take off the plastic cover. take off the two bolts off the timing belt tensioner, remove belt, put new belt on, and reverse process. Change that water pump while your at it, its the only way to get at it also (to remove timing belt).
PS this is for a 1jzgte, but 2jzge has to be almost identical process
VJ RC51 takes about an hour. Remove fan, rad, covers. line up crank pull to Tdc on the bottom cover, and make sure the cam marks line up with the marks behind the gears. Use a 3/4in (not 1/2in) impact gun to remove the crank bolt if its never been off. A 500FTlb 1/2in wont budge it if it was never off. Use a puller to get the crank pulley off. take off the plastic cover. take off the two bolts off the timing belt tensioner, remove belt, put new belt on, and reverse process. Change that water pump while your at it, its the only way to get at it also (to remove timing belt).
Dude, what are you the Yota Guru!! When you go to sleep at night, do you see Intakes, and Cam shafts....
Awesome quick write up!!!!
Don't do it if you do not know how...
Also if you don;t have burly impact wrench. Use a big breaker bar, and set it on the ground, and blip the ignition and us eteh torque of the starter to break the bolt loose. that will work, old school trick.
Honestly its not hard, but if your gonna be changing teh belt, i would suggest and go ahead and change water pump, oil pump, and anything else that may require refurbishing.
Zombie Slayer
Originally Posted by VJ RC51
i had no idea how to do it either, and it took me 45mins start to finish. Dont discourage people from working on their cars, u should ENCOURGE it!
I agree. Unless your hands consist of five thumbs or you have cash just falling out your pockets......give it a try. Learning how to do repairs to your car is an invaluable experience.
Had my SC4 for 2.5 years now. Hasn't seen a shop yet. All work done by me. Some jobs were first time deals too. Search through CL and you'll find a write-up for just about anything!
Zombie Slayer
Careful with that technique. Old school and it does work, but a slight mistake and..........well we don't wanna discuss that!!!!!
Also if you don;t have burly impact wrench. Use a big breaker bar, and set it on the ground, and blip the ignition and us eteh torque of the starter to break the bolt loose. that will work, old school trick. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
i've done that trick time and time again no problems here. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
lol your on your own with that one. i can just picture some n00b doing it and chipping teeth off the flywheel as we speak
