manual conversion Q
to get the car started just jump the black wire and black with white stripe wire on the grey connector next to the trans. i just finished my conversion today and started right up on the first start. and if you want to run a clutch switch im pretty sure you can just tap into those two wires. i just used a paper clip for a temporary fix. im gonna solder them together later on. i am also running the auto ecu
ok, well my car is cranking now, but it wont start... i dont believe i hear the fuel pump turning on...
car ran fine before auto to manual swap... again, only pedal is not hooked up, also there is a plug on the side of the tranny that is not plugged in, no connectors on the harness fit it...
the only other thing i messed with was i changed the exhaust manifold... that wouldnt prevent the car from starting...
i also tried both ecu's auto and manual...
I just suck i guess... lol, help me please.
just looked at my car again today to try and figure things out...
like i said i cant hear the fuel pump coming on, it is also not getting spark or an injector pulse...
the fuses and relays are all fine...
what the heck is going on?
Blk97SC300
Performance & Maintenance
26
03-31-09 11:48 AM
sniper
02-02-05 02:02 PM
