need help bad (electrical issue)
Old 04-09-06, 10:03 PM
DEMIK
DEMIK's Avatar
Default need help bad (electrical issue)
94 sc300 5 speed....
after installation of coilovers its scraped the harness under the drivers fender and caused the guage cluster lights to turn off. i fixed the wiring and raised the car. cluster lights are on. but now it will not crank. also when ever the car is in the ON position and i have my foot barely on the clutch, the oil light , rear light malfunction light, and BRAKE light goes from dim to bright depending on how much pressure i give the clutch...... the car drives fine but i just got to bump start it..
and the starter is new and working proberly. all fuses were check out fine..
PLEASE help. thanks in advance
help me solve and ill give u something
afree
IS - 1st Gen (2001-2005)
07-23-15 04:05 PM
Emackny
SC- 1st Gen (1992-2000)
03-22-09 12:23 PM
lexoman562
Suspension and Brakes
03-26-07 09:26 PM
Quick Reply: need help bad (electrical issue)
