SC300 -> 2JZ-GTE
Old 04-17-06, 03:21 PM
GReddySetG
GReddySetG's Avatar
Default SC300 -> 2JZ-GTE
OK, I did a search, and could not come up with the answer. I'm swapping a 2J with auto tranny into a '93 SC300, also automatic. The driveshaft is diffrent. Anyone know how to solve this problem?
Old 04-17-06, 03:48 PM
TurboB6
TurboB6's Avatar
Simple Buy a one-piece or the SC400 Driveshaft.
Old 04-19-06, 12:53 PM
GReddySetG
GReddySetG's Avatar
So the SC400 driveshaft will bolt up to an automatic Supra tranny, and the other end will go into the stock SC300 differential?
Where would I buy a one piece?
Old 04-19-06, 12:57 PM
Luv Da Lex
Luv Da Lex's Avatar
Get it custom
Old 04-19-06, 01:17 PM
TurboB6
TurboB6's Avatar
Phr, SP, Wotm, etc.. Should all be able to get you a One-piece Driveshaft. Along with this mod you need to change the flange on the diff carrier though.
The SC400 driveshaft bolts up without mods if I remember right but once you start putting power down I wouldn't trust it imo.
Old 04-19-06, 02:57 PM
GReddySetG
GReddySetG's Avatar
Do you guys have any links to where I can get a custom one or one from one of the above mentioned manufacturers.
Old 04-19-06, 08:56 PM
TurboB6
TurboB6's Avatar
I don't believe there are any links to these driveshafts. Best bet would be to call whoever you want to do business with up.
Old 04-20-06, 02:14 PM
DETUNED
DETUNED's Avatar
When we did my 6 speed swap with 6 speed rear end, we used a 6 speed supra drivesahft and extended it about 5.5 inches using another driveshaft, all we did was cut and weld to the proper length, then I brought it to advanced driveline (local driveline place) and they made me a nce beefy one.
Just call around your local driveline places and i'm sure they can help, as long as you have the 2 ends.
Old 04-21-06, 08:45 AM
ummagawd
ummagawd's Avatar
greddysetgo.... wuddup man... remember me from the mr2oc board?
i see you finally got an SC
Old 04-21-06, 01:02 PM
GReddySetG
GReddySetG's Avatar
Yeah, I actually have 2 SC300's. Had them for a little while actually too, just started modding one though. And as you can see, having a little trouble with the swap
zazzn
03-02-17 02:48 PM
xspsi6
12-28-11 09:08 PM
suprandsc
07-20-08 10:17 PM
05RavenR6
12-25-05 12:37 PM
JZ30
07-19-03 07:56 AM
Quick Reply: SC300 -> 2JZ-GTE
