New to me, maybe not to you (ps pump 1jz)
My PS pump went sour (sounds like peters
) so i was checking my parts bin around the garage. Apparently, the 2JZGE non turbo PS pump is the same exact pump as the 1JZGTE turbo power steering pump. You just remove the tank off the 2JZGE pump and put the hose adatper on from the 1JZ pump. I figured they were the same, toyota wouldnt make all sorts of different parts for each car.
Problem solved![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
So basically, from your sc300 2JZGE to a soarer 1JZGTE, every accessory is directly interchangeable except water pump (thats 2jzgte).
Problem solved
yup....same pump...even has the same flange for the adaptor that goes to the hose for the tank. make sure you put a new o-ring in there....mine leaked from there and was so old i couldnt even get it off without it cracking
Originally Posted by DETUNED
Yeah, I actually used my GE pump on my GTE since I didn't have an extra one, but as soon as I got the car on the road, it went south.
Also its time for another set of replacement urathane rack bushings. The ones off luxurymods.com are trash. Now that daizen makes them, i think they might last longer then 6 months hopefully.
