Clicking noise
Old 04-19-06, 03:36 PM
Tymboo
Tymboo's Avatar
Angry Clicking noise
Help!!!! I'm getting a clicking noise coming from my front passenger side wheel. I usualy hear it when driving 0-25 mph has anyone had any this problem b4..
Old 04-19-06, 04:07 PM
VJ RC51
VJ RC51's Avatar
usually = wheel bearing
Old 04-19-06, 04:33 PM
bishoptane
bishoptane's Avatar
to check jack the car up so the tire is off the ground and grap the tire at 3 and 9 oclock and try and pull with one hand and push with the other and then the other way, if you move it more than,???? i dont know like .10 it means its the bearing. i could be mistaken but you should be able to tighen it up. but if it wore out, its wore out and need to be changed hope this helps.
Old 04-20-06, 04:05 AM
vipsoarer
vipsoarer's Avatar
check for a nail/screw/glass/rock in your tire also. after about 30 its oscilating so fast that you cant hear it and it blends in with the tire noise.
Old 04-20-06, 06:49 AM
np20412
np20412's Avatar
loose lug nuts may also be the culprit...even if 1 or 2 are loose.
Old 04-20-06, 10:51 AM
recoil
recoil's Avatar
i am having a similar iss ue but its the rear dirver side.
its a random clicking noise (like metal on metal) when im going below 15mph, pretty much just rolling.. its not even constant.. mor elike a: tink..tinktinktink...tink..tink...
then as you accel. goes away....
I will have the wheel bearing inspected... I already rebuilt all 4 calipers and did full brake job but sound persists.
hehehe, SC at 3 issues: sub02 sensor, TRAC light is on always, and now the clicking,
but she's still driving strong at 200,000!!!!
Old 04-21-06, 10:26 AM
kaosman
kaosman's Avatar
Check your halfshafts, that sounds like it could be a CV joint.
Old 04-21-06, 11:33 AM
Tymboo
Tymboo's Avatar
Red face Ok
O ok ill try the wheel at 3-9....I just had the tires changed I should have did that at the same time...Thanks for the help everyone!!!
Old 12-10-07, 07:20 AM
turbohye
turbohye's Avatar
This is also going to depend on which wheel its coming from. Do a search and you will find many culprits from the simple to the complex.
uncandid
01-04-19 08:39 AM
AntPulido
Performance
03-18-14 12:50 PM
tsitalon1
03-30-08 12:21 PM
Armand
10-09-07 04:53 PM
skins990
06-05-03 03:23 PM
Quick Reply: Clicking noise
