How do you adjust ignition timing on the SC300
I know it is done by rotating the distributor; but the serivce manual calls for a special probe to be installed when setting the timing. Is this probe just a jumper?
Any other tricks?
-Mr. Wigggles
Any other tricks?
-Mr. Wigggles
Yes, you bridge to connectors on the ECU tap under the hood. I forget which pins. A paper clip would work fine. It must disable some of the timing advance related components in order to get a truer reading of the actual dwell angle.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
take the cap off of the distributer, turn the crank pulley until the tip of the rotor is set at the number one wire (TDC 1) i hope this helps you out.
330, 92, adjust, adjustment, advancement, ajust, clip, distributor, ignition, lexus, paper, rx, sc300, set, timing
