the best torque converter for a SC400???
Old 06-03-07, 08:38 PM
b1ackhawk
b1ackhawk's Avatar
I would imagine that getting your stock TC rebuilt to a higher stall would allow you to keep your highend power because you will still have lockup about 40mph, giving you better 1/4 times,and keep fuel economy.
Old 06-04-07, 10:42 AM
sc400injen
sc400injen's Avatar
Straight up, been runnin' a Dragon with a 3200 stall in my 92' sc4 for about 2 yrs. and definitely one of the most valued of my upgrades. Goes good with my intake, custom borla exhaust, NX wet 75 shot, and ls4 brakes 4 tha stop.
definitely a noticable difference in takeoff....
-Knowledge
Old 07-20-09, 06:06 PM
AyDee
AyDee's Avatar
My Lextreme TC it did make a little difference to my take off - I have noticed that the car starts moving at 2200 RPM not 2800 RPM and that might be the reason why I did not feel a huge difference- It could be that the one I received was a 2200 stall RPM
How can you know what is the stall RPM on ur TC? What I read somewhere is that I should hit Gas and Brake at the same time for about 4 seconds, and wherever my RPM needle stops is the actual TC Stall Speed
If this is correct then my Lextreme one is 2200
Old 03-02-10, 09:56 AM
snowfox444
snowfox444's Avatar
i was researching upgrades for my car. i just bought the 95 sc400 and saw the dragon TC. well if im gonna upgrade my car - i wanna go all out maybe not all at once, but I plan to treat it like my queen! i cant do the upgrades myself, i know nothing of mechanics besides like changing tires and a older 90's Camry alternator... im wondering where do i get the Dragon Torque Converter part, and what kind of mechanic i should have put it in? could a local AAA certified garage do it? thanks..
Last edited by snowfox444; 03-02-10 at 10:23 AM. Reason: too wordy, keeping it simple.
Old 03-02-10, 11:10 AM
Ali SC3
Ali SC3's Avatar
i think any shop that can rebuild automatics could probably do it.
Since youll be bringing your own part theyll tell you 100 times over that its not warrantied, but a good transmission shop rarely messes up a straight forward install.
Old 03-03-10, 02:56 PM
snowfox444
snowfox444's Avatar
is it normal to rev up to 5000 rpms when hitting the pedal full throttle at a dead stop before taking off at a decent speed? because otherwise, i might just have to check if the tranny has a slip because it seems a little sluggish... I wouldn't want to put something that expensive into a trans id have to fix first.
Thanks by the way
Old 03-07-10, 05:21 PM
jdm93400
jdm93400's Avatar
does anybody know how much these are?
Old 03-09-10, 11:33 PM
stevechumo
stevechumo's Avatar
I really don't know how to test the TC for sure, but the belief to brake-torque the car and see when the car will start spinning at a certain RPM is completely wrong. I have the same 2800 stall rate TC, but after I increase the boost and tuning, the wheels start spinning at around 1500 RPM. I don't remember at what RPM the wheels started spinning before the boost increase, but they spin so much sooner with the boost increased. Does that mean I my TC is at 1500 RPM. I don't think so.
Old 08-28-14, 11:15 PM
Carueaga
Carueaga's Avatar
Default I would like a quote for my TQ and what stall
I have a twin turbo supra now it is converted to a single turbo I have a lag to about 2800 rpm but it's my car I drive 3 days out if the week. I would like to have have stall better then stock but easy to drive in traffic maybe at 2200 rpm please let me know if you can mod ? How long ? Where do I send it to.
Thank you
James Carvajal
Jamescarvajal008@hotmail.com
Originally Posted by jibbby
The Dragon Torque converter is probably the best TC and most expensive....$900
Lextreme.com offers a cheaper deal where you send your TQ in and that then it is reworked with a good stall rate and then mailed back to you for around $400... They come back in good shape and is almost as good as the Dragon.....
Any transmission shop should be abel to install for no more then $300
This is not a cheap mod but probably the most important...Good luck
818sc400
12-10-07 10:03 PM
want sc300
11-18-07 03:13 PM
laxdude362
49
02-07-06 06:35 PM
whago
08-20-01 01:58 PM
Quick Reply: the best torque converter for a SC400???
