Auto-auto tranny swap questions
First off, yes I searched and could not find what I needed. Ok I'm new to this board and new to Lexus but have had and worked on many other cars but my question is will a 94 Supra TT automatic tranny bolt right up to my auto 93 SC300? The reason I ask is I can get the Supra tranny for free and right now the stock tranny isn't doing any good, the boost hits so hard that it just goes straight to the rev limiter and I have to take my foot completely off the gas for the car to shift in 1st and 2nd gear, it's not as bad in 3rd but still I need to do something. I would guess that the TT auto tranny is most likely stronger and I know for a fact that the tranny shifted perfect nearly every time when it was in my friend's supra that was putting right about the same amount of power to the ground-400+ so will it bolt right up? anything that needs to be done to make it work? thanks in advance
The supra tranny holds a very good amount of power.
The problem is, you wont be able to mate the tranny to the 2jz-ge. It takes too much work to do it.
The reason being is the SC transmission is line controlled, where as the Supra transmission is electronically controlled.
The TT tranny will bolt up using the TT Bellhousing, TT Flexplate, TT TorqueConverter and TT rear support. You will also need an ECU to control it. AEM works.
You will also need a new drive shaft. The SC400 drive shaft will work, but a custom 1 piece will work better.
Its worth the swap IMHO.
gadgetSC-t
gadgetSC-t
gadgetSC-t
gadgetSC-t
Originally Posted by Idrewfelix
When you can get a boostlogic built tranny for $1800 with core exchange?
There is a boostlogic transmission made for the SC/ NA Supras.
http://www.boostlogic.com/parts_supraNA.html
Your stock transmission wont hold much longer with that kind of power. Mine began slipping around 3-4 months daily driven.
Banned - could not follow forum rules
A good Supra TT Engine is hard to find these days...I live in LA the car mecha for used auto parts...Go for the swap if you can....Those motors can pull an SC300 very hard....Same subframes and the swap should be doable as stated above...Grab as many parts off that Supra as you can, Brakes, control arms, suspension, Torsen LSD, etc...It all fits....
