not idiling as well as she should
ok heres the story im now the proud owner of a 92 sc3 and i love the car and i just got it like a week ago but i can tell im going to have fun , now here in lies the problem when i turn it on she perks up to like 2 grand and then drops to, about 800 and starts to loud like it has one of the biggest cams in it youve ever heard, and then today b4 this happened it would start come to 2 grand and then die , now im not sure how or even if i can set the idil on this yota or if im in over my head when i give her some gas she stops all that bs and comes to life so im pretty sure its nothing overly bad just anoying to have a great car idil like hell at a stop like and help would be grateful message me or just call my cell thanks again
use a paper clip and connect port fp and b+ in the diagnostic port by the engine,
see if it starts right up
there should be a diagram of the ports on the port cover.
if it does then your fuel pump ECU is bad.
ok ill try that thank you, i mean it almost like its not getting enough fuel or spark, but at higher rpms its running fine, and i mean theres plenty of power and torque, could just be as simple as a new set of plugs? i feel like and idiot and im sorry to those who read this a curse at me.
I'd try the basic maintenance items. New Plugs, wires, Distributor & Cap & Rotor, Reset the ECU (pull the fuse or take off the battery cable for 5min). Then see how its running. Might also want to clean out the Throttle Body with some carb cleaner while you're in there if you haven't done any of this.
same problem maybe
Hmm. I think I have the same problem-- sorry I had a little difficulty reading your entry b/c there were no punctuation marks.
My car's been running fine whenever it's not idling. The car flat out died on my twice or three times in the last week on the road when I was cruising at 5 or 10 mph over the speedbumps near my apartment ( I have an automatic btw). The mechanic couldn't find the problem last week. Finally, when i was driving this week the check engine light came on and stayed on -- last week it would come and go, but of course when I bring it to the mechanic, it's not there.
I did the self diagnostic thing with the jumer wire to read the engine codes and i believe code 41 and 71 came on. 41 i think is for the TP (throttle position)sensor and 71 is for the EGR sensor. I'm getting the car looked at the shop now, but i'll keep you posted.
Also, watch that screw. My one basically broke when I tried to turn it. No idea why it did that
Jonny
Got the car back from the mechanic. The EGR code was just a loose vacuum hose, but the TP sensor was a little more serious. He told me to replace the part. Man, i can't remember which part he said -- throttle body or something. Anyway, the part is $140 and he wanted 1 1/2 hr of labor, so I told him I'd think about it. I asked him if cleaning the part would help, but he said since the part is sealed, dirt wouldn't really get in.
For now, I think i'm just going to use the good old ac trick. I have to call again to ask which part needs to be changed.
whiteysc
SC- 1st Gen (1992-2000)
08-03-11 02:42 PM
andibogard
GS - 1st Gen (1993-1997)
16
02-26-11 11:36 AM
MCG33
Performance & Maintenance
07-12-07 11:59 AM
