Wth Is Wrong With My Car
ok everyone.
dont get annoyed by me or anything. i'm just here to ask for some help. i did search and i didnt find a thread that relates to any of my problems. so hear me out on this one PLEASE.
ok. so before the whole tragedy happened, i had a problem with the car surging and hesitating.
so i thought, i'll replace the fuel filter. so i go and try to replace the fuel filter, and i end up twisting the intake side of the fuel line. the one that goes back into the fuel tank. so i go and get one from a dismantler ( a BIG mistake because my dumbass wanted to hurry and fix the car) and i end up replacing the fuel line with a new fuel filter on. i checked all the connections, and there were no leaks on it. so i go and try to start the car, and the car has a hard time starting. so i'm guessing that its probably because i drained the whole fuel tank, so i give it 3 tries, and it barely starts up. i start pressing on the gas, and it idles a little low, but its fine. one thing that happened after i did this is that i noticed the engine started shaking real bad. but anywho, i pulled it out of the driveway, and i start to go down the street, but the car has no throttle response AT ALL. i started stepping on the gas, and it wouldnt budge. so i some how end up driving to the nearest shop that i go to often and i have them check it out. they call me the next day saying they checked the MAF sensor and some other stuff. they checked the fuel pressure and it was at 11 PSI. so they suspected that it would be the fuel pump, so they go and replace that. they checked the fuel pressure, and they said it shot straight up, then right after that shot straight down.
so now i'm kinda confused cuz all i tried to replace was a freaking fuel filter, and it lead to all this mess. take a note that the fuel filter was replaced, the fuel line was replaced, the fuel pump was replaced.
anyone have a clue whats going on?
and to add on top of all this mess, i'm on the edge of getting fired at my work because the shop is taking almost a week with my car!!!!
please help me!!!!
thank you for at least reading my novel.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
please help me!!!!
Well you MIGHT don’t hold me to this but when you replace things like that which travel in 'lines" or hoses if you break loose a particulate it will go down the route and do some damage there...
So I think you might have knocked something loose when you might have pinched the line... maybe some metal shavings? and that did the damage...
Just an idea
Hope it helps
-Tommy
Just an idea
Hope it helps
-Tommy
so u mean when i pinched the line and started the car, some metal shavings went somewhere?
well, i did tighten the lines to the new fuel filter with the pinched fuel line on. and i started the car, and the part just spewed gas all over the place.
i'm positive that when i replaced the fuel line, the line didnt have any pinches or bents on it.
what i'm guessing is that all the dirt and what not from the fuel line that i put in is causing this mess.
can that be possible?
hhhmm, it could be the ignition and fuel injectors.
i do have a new cap and rotor for the distributor, and new spark plugs. maybe i should tell them to put those in and see how it runs.
i even put those fuel system cleaning things, and it still does it.
i greatly appreciate your thoughts.
more thoughts would be greatly appreciated.
I had some fuel pump wiring issues after my gte swap, I was running a TT fuel pump in the stock location. It stopped working and I found it was not getting power. Why I relate this is that I had to literally hard wire the fuel pump to drive it to the shop who installed this to get it fixed.
Ok, message for you is that you can hot wire the pump buy removing the rear seat upper cushion, pry that circle cover off with a putty knife and you'll see the wires there. Then you know for sure that you've got power and steady fuel pressure because it will get a full 12v. If it runs well hot wired then you know you've got a fuel pump ecu or wiring issue going on. (I used a length of 14 gauge speaker wire from the battery through the cabin to the rear deck.)
but the problem wouldn't be that imminent, I wonder if there's a problem with the new fuel pump....or somewhere your sucking in air and losing pressure.
random thoughts.....sorry if no help
Originally Posted by simonsays
ok guys.
i got my car back from the shop yesterday.
its all fixed now.
the problem was the fuel pump ECU.
sucked ***** cuz it cost me 500 bucks.
its all fixed now.
Felix is right on and this was discussed on this forum years ago- that ECU just lowers the voltage during mild driving and while I'm not saying it should be removed if it's working fine, there's no economical reason to go through the expense of replacing it if it fails.
In fact, without the ECU your car is more reliable, as simon just proved.
jamestravo
05-19-17 10:01 AM
