Sc400 aftermarket radiator????
I search!!!! Koyo Radiator but i think it was made for the supra. Is there one that fit the o.m.e. fan for the SC400? If theres any pics of aftermarket radiator on a Sc400 post it. I'll like to see your setup.
Thanks
Thanks
As far as I know they wont, bc the supra and 300 have smaller radiators than the 400 so the mounting brackets aren’t the same... could u fit it... yes…
but again those radiators are meant to cool I6's not a V8... just some food for thought... unless you go after market....
-Tommy
-Tommy
The Koyo all aluminum Supra TT three inch radiator is massive and more than capable of handling the SC400 v-8.
The 2jz-gte engine's output (both h.p. and heat generated) are higher than the SC4. Also, the engine bays all have the same bolt patterns, your SC400 even has a fender pass through for a SMIC as found in the Soarer.
The TT KOYO radiator that is an upgrade over the oem Lexus or Toyota TT. It bolts right up, but I have no idea about where the radiotor hose routing is on the SC4.
Originally Posted by Sc1UZ-FE
Well im going with the supra TT radiator. Thanks for the info. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
You can run a Supra radiator, but it will need two rubber lower shock mounts stacked together for it to fit snug when clamped in place by the upper radiator rubber mounts.
-scott
Originally Posted by motorheaddown
It won't fit "as is". The Supra radiator is not as tall as the radiator designed for the sc. Fan shrouds are different, too. I know this from experience.
-scott
-scott
RedPhoenix
Performance & Maintenance
17
07-05-08 11:46 PM
