98-00 SC400 Compatible Engines?
Old 05-11-06, 06:37 PM
CyberSC4
CyberSC4's Avatar
Default 98-00 SC400 Compatible Engines?
Bad news with my car. Without going into details. I need a new engine for my 2000 SC400. Anyone know if the 1UZ from a same year GS400 or LS400 will fit and work?
Old 05-11-06, 07:15 PM
laxdude362
laxdude362's Avatar
OMG NO!! What happened? Your car is by far one of my favorite ones on the forum! Anyways I would think that the engines from the LS4 and GS4 would be compatible since they are the same size. Although something is different with the GS4 engine b/c it is rated at 300hp while the LS4 is rated at 250hp to 290hp through the years. I guess the GS4 is tuned differently than the LS4 due to it being a luxury "sport" sedan. Any reason you aren't looking at just getting another SC4 engine?
Old 05-11-06, 07:31 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Same motors buddy. Just different ecu's and there for timing and such that’s why they have different outputs
You should be fine.....
-Tommy
EDIT:Since your in so cal give me a call if you have problems sourcing an engine I know of a lot of junk yards that might be able to help!
Old 05-11-06, 07:48 PM
ISC400
ISC400's Avatar
the only reason the GS has a higher rating is because it brought less restrictive exhaust manifolds than the SC or LS. And you should be good with any VVT-i 1UZ-FE, by the way you mind saying what happen to your motor its really rare to hear about these motors breaking down for good?
Old 05-11-06, 07:52 PM
CyberSC4
CyberSC4's Avatar
Yeah, I'd really appreciate it if you could help me locate a replacement engine. Having a hard time locating a 98-00 SC400 1UZ engine. So that's why I was wondering if something from the other cars would fit and be relatively plug and play.
Please let me know. It's a pain in the butt right now because I have no car and use my folks' van after dropping them off at work at 5:30am.
Anyone that can help with a replacement engine, please let me know via PM. I have faith that the CL family can help me get her back in working order.
-Tommy
Old 05-11-06, 07:57 PM
Lexiss_sc430
check ur pm
Old 05-11-06, 08:43 PM
laxdude362
laxdude362's Avatar
[QUOTE=lexiss_sc400] Same motors buddy. Just different ecu's and there for timing and such that’s why they have different outputs
-Tommy
QUOTE]
What was that about? I know their the same engines but I just didn't know what was different, that's all.
Old 05-11-06, 09:10 PM
Lex*Toy
Lex*Toy's Avatar
Im sorry to ask, but I've never heard a VVTi SC400 blow the motor. Can you tell us what happened?...maybe it isn't really blown...
Have you considered this? How do you know for SURE???
Old 05-11-06, 09:15 PM
millions
millions's Avatar
They are the same motors, except for the oil pans/sump. SC's are rear sump cars, whereas the ls and gs are mid sump. You'll have to swap oil pans to get an ls/gs motor to fit, but other than that it'll drop right in.
Old 05-12-06, 02:38 AM
Lexiss_sc430
nothing man it was just a reply... sorry if it came out otherwise.
-Tommy
Old 05-12-06, 09:12 AM
CyberSC4
CyberSC4's Avatar
Here's what happened the other week. I was driving home at night and in the middle of a left turn the car suddenly dies. No power anything. I had enough momentum to coast to the other side and turn off the car. Trying to restart the car and the thing cranks but won't turn over without applying major gas. Once it got it to start, it makes this terrible noice like clankety-clank...clankety-clank (not good). Got it towed to the shop next day. CEL scan shows P0300, multiple random misfires. My mechanic checks everything and eventually finds no compression in two cylinders on one bank. Open it up and the valves are bent in those cylinders. Sent the part out to the machine shop and got it back the other day. Reinstalled everything. Started it up (starts fine now), but clanking sound is still there and very loud. Today he is checking the crankshaft for damage.
Maybe it'll be repairable (I hope). But I wanna be prepared just in case. I have no idea how this happened. The car was running perfect up until that day.
I still love the car.
Old 05-12-06, 10:50 AM
ACleanSC4
ACleanSC4's Avatar
wow, sorry to hear about your unfortunate mishap kevin...
I'll trade ya mine for yours
Old 05-12-06, 10:18 PM
Lex*Toy
Lex*Toy's Avatar
I would suggest you post your problem on the GS forum, since more of those guys over there have the VVTi than SC owners do.
Sounds like a timing issue to me...did you have that checked to make sure that pistons weren't bending your valves?
Old 05-20-06, 06:27 PM
CyberSC4
CyberSC4's Avatar
Default OMG I can't believe it
She finally back home! Two weeks. Two new pistons and rings, three new valves, heads cleaned up, new plugs, new air filter.
Felt great to hop in today and drive her home. The downtime seemed like forever. Now it honestly feels like a new car.
Thanks for everyone's support. I really appreciate it.
(back in her old spot!)
Old 05-20-06, 06:30 PM
CyberSC4
CyberSC4's Avatar
cleaned up and good to go
Quick Reply: 98-00 SC400 Compatible Engines?
