2JZ swap into SC
2JZ swap into SC
this is probably the stupidest question to ever be asked on this forum, and no i didn't search...so flame away
i know it is possible into an SC300, but i was just wondering if it was as easy/possible to put a 2JZ into an SC400
So other people should take the time to respond to you, but you can't take the time to search.
Jonny
not impossible not as easy as an sc300 but do-able just takes more there is a guy on here who recently had it done. you will need the k member and a few other things its common sense just think about it
Jonny
better not.
soarer479 is correct its been done - PLEASE SEARCH.
Why would you want to do that swap what would be the benifit? This may warrant a ban (just kidding) If anything step up to the Tundra 4.7 motor and ECU swap but you just will need a new intake setup to make that engine fit under the hood of the SC.......Manifold and stuff stick up to far, I measured and was considering the swap a few months ago....
Hey man not to bash on you or any thing all I did was type in "2jz SC400" the search bar. We had this up about a month ago.
https://www.clublexus.com/forums/sho...ight=2jz+sc400
The 2JZ series of toyota engines CANNOT fit in the SC300. The SC300 engine bay is designed for a 4 cylinder rotor and doesnt come with enough engine space to support an inline 6. Much less a 8 cylinder 3JZ-GTE
please excuse my out break that is about to happen.... that tundra motor is a piece.... literally the last two i have worked on had the trd charger headers full exhaust intake and a crane cams regrind running 5 psi and tuned they both put down under 300 whp ..... well under 300 which is rediculous ive seen other make much more but if these are only make that out of a 4.7 liter v8 that is seriously pathetic ill take a 1uz fe any day ... or even better a 2j
MR VTEC
SC- 1st Gen (1992-2000)
04-11-03 06:05 AM
