How can you tell if an engine is obd1 or obd2?
Old 05-17-06, 03:08 AM
joshthorsc
joshthorsc's Avatar
Default How can you tell if an engine is obd1 or obd2?
I have a bad headgasket on my 92' SC300 and will be going to Attarco this Thursday to take a look at engines. I was wondering how can you tell if an engine is obd1 or obd2? Attarco said they have 2-4 2jz's but not sure if they are obd1/obd2.
All I know is that the vvti are obd2, but the 96-97 did not have vvti. Would a 96+ motor pass smog on an obd1 vehicle considering they came off a obd2 car?
I've tried searching and cannot find the answers I was looking for. Thanks!
~Josh
Old 05-17-06, 08:00 AM
Dx3
Dx3's Avatar
~Josh
This is just a guess, but don't they stamp the VIN on the block? If so, and if you do some research, you should be able to decipher the VIN to see what year the motor came from.
Jonny
Old 05-17-06, 08:56 AM
KidPandJ
KidPandJ's Avatar
"Would a 96+ motor pass smog on an obd1 vehicle considering they came off a obd2 car"
I don't believe an OBDII motor will work with a OBDI ECU..as far as telling which one a motor is, i guess your best bet would be to do what Dx3 said.
Old 05-17-06, 09:12 AM
soarer479
soarer479's Avatar
92-95 is obd1 96+ is obd2 simple look at the maf if they have one with it if not look at the o2 sensors on the headers obd1 is single wire o2 and obd2 is 4 wire
Old 05-17-06, 10:26 AM
Sc1UZ-FE
Sc1UZ-FE's Avatar
soarer479
Just about to say that
Old 05-17-06, 08:37 PM
joshthorsc
joshthorsc's Avatar
These are exactly the info I need. Thanks for the replies!
~Josh
equix8
05-30-15 09:07 PM
Javi3r801
05-16-15 02:28 AM
DriftNsc3
04-08-07 02:12 PM
PandaSC300
06-01-05 02:44 AM
Dealer Xing
SC- 1st Gen (1992-2000)
07-19-02 10:28 AM
Quick Reply: How can you tell if an engine is obd1 or obd2?
