Altering the MAF?
Old 05-20-06, 05:29 PM
jibbby
Banned - could not follow forum rules
jibbby's Avatar
Default Altering the MAF?
I am looking at this Mass Air Flow unit, and it looks to be the most restrictive part of my 1992 SC400 intake.... I have an extra and started experimenting, took off the mesh screen and the car ran like crap, thought about grinding out the insides then thought twice about it...This unit is very sensitive...Would love to open the flow and get a larger throttle body...Any known upgrades for this? Does switching to MAP have any advantages? Any uprgradeable newer SC model MAF's swaps that someone is aware of that work?
Here is a picture of what I would like to alter and make bigger somehow and still have my car run right.....Anyone?
Old 05-20-06, 05:32 PM
jibbby
jibbby's Avatar
One more pic....
Old 05-20-06, 11:37 PM
rscott
rscott's Avatar
its definitely the most restrictive part but there isnt much to be done. since its a karman unit its very sensitive to almost any changes that are made. the screen is there to help linearize the airflow to get a more accurate reading. you shouldnt be outflowing it unless youre running forced induction though. remember with the intake at NA intake volumes its more a matter of streamlining airflow over increasing passage area since relative to FI cars, the intake air demand isnt very large.
Old 05-21-06, 10:36 AM
jibbby
jibbby's Avatar
THanks for the info, that is pretty much what I thought... I have tried altering and tinkering with the stock MAF and had no success......A very sensitive unit to change.....
Best flowing intake for an NA 1UZ...would be these little babies...Too bad they are not practical for street use...
Old 05-21-06, 11:28 AM
jibbby
jibbby's Avatar
This is another pic of the 1UZ-FE aftermarket intake manifold....Oh those little throttle bodies!!!!!
Old 05-21-06, 11:33 AM
JTJerryls400
JTJerryls400's Avatar
on 1g 4G63 Turbo mitsubishi engine there was karman too. I swapeed it for vette MAF and maf translator. they do translators for anothers cars. even for supra mk3 turbo with is very similar to sc400. Now they have something that can change from karman not only to hot wire but for MAP too.
Jerry
Old 05-21-06, 03:51 PM
jibbby
jibbby's Avatar
Jerry - do you have a picture of that swap? How much better do you think it flows? No problems to mention?...
Old 05-21-06, 07:33 PM
jgscott
jgscott's Avatar
Received 1,409 Likes on 1,114 Posts
Yeah Jerry about a little more details. Are you saying the the Vette MAF and translator will wire directy in and work ? Or do you have to use a ECU to program it in to drive right ?
Old 05-22-06, 06:53 AM
JTJerryls400
that was for my 4g63 turbo motor. that is 4 cylinder 2 litre car. engine by mitsubishi.
there is something called maf translator. you simple remove stock kaarmann maf and putting gm 3 or 3.5 or 4 inch hot wire maf and there is device thatn can by adjust as safc. so you will have no restriction (put 4" gm maf) and tunable device that alerting maf as safc. that device is calling TRANSLATOR. originally that was for buick community, next for mitsu and now it is availe for mk3 supra too.
company have forum too
look there:
http://www.fullthrottletech.com/
that device is simple and it was work extemly well in my 4g63 turbo engine. maf cost about 100-150$ and translator $200. for 300-350 $ you have no restriction and safc in one.
Jerry
Old 06-05-06, 04:11 PM
CleanCL
CleanCL's Avatar
this is very interesting. after i finish my exhaust work, i am going to look into this.
Old 06-05-06, 05:43 PM
jibbby
jibbby's Avatar
Don't bother I already looked into it big time...You can have a dual MAF but that is mainly used with a twin turbo setups or you can switch to an MAP and that is about it....Not much more there to work with in regards to our stock MAF's.... ....
Old 06-05-06, 09:14 PM
CleanCL
CleanCL's Avatar
thanks for the heads up, my previous car had the same thing, pain in the ***. but i'm still going to make my attempt at a strong n/a setup, regardless. i'm trying to stay away from the huge costs of custom turbo/blower.
studzz12
IS - 1st Gen (2001-2005)
05-30-13 08:04 AM
NCis300
03-10-12 09:16 PM
socal72
SC- 1st Gen (1992-2000)
15
07-06-10 04:57 PM
Drewbeeee
07-23-07 11:03 PM
1BadAzzLex
01-16-03 01:28 AM
Quick Reply: Altering the MAF?
