NA-T guys, what'd you do with the O2 sensors?
Looking to piece together my turbo kit and i was just curious what to do with the O2 sensors after the header, do you run O2 sims or just install them to the down pipe?
Originally Posted by supra dr
Correct for the fronts, but you will need a simulator for the "after cat" O2. (unless you really
have a cat)
have a cat)
Sorry to dig up an old thread (I did search here and clubna-t) but by the title I figured I would ask this in this thread to keep all the info in the same spot. I am in the middle of a NA-T build in my friends 92 SC300. Since the DP has thread in style O2 bungs, and the stock sensors are flange style, what sensors should we use? I have read about using one sensor and feeding the signal to both bank 1 & 2 but is there a thread in sensor I can use for the signal. I would prefer that over welding a new flange in the DP for the stock sensors.
Thanks in advance,
Ki
Thanks in advance,
Ki
