traction control light
My traction light just came on and I don't have traction control on my sc 400. The e-brake light came on with it as well. Any sugestions????
help
I am a new to this and I posted a new thread and can't find it so dont get frustrated. My tyraction control light came on and I have no traction control on the car. Also the e brake light came on as well. Its a 92 sc 400.. Where to start looking for the problem?
ooh. Found other message...sorry.
Thanx.
Thanx.
Welcome...
Would your brake fluid be below minimum in it's reservoir? This usually indicates you brakes need to be inspected or serviced (replaced). The brake fluid displaces the wear of the brake pads.
the trac off lite has something to do with a sensor im not sure which one, and sometimes when ure trac off light goes on ure check engine light will also. as to the brake question I am not to sure good luck though
Search
If you did an Advaced Search, typed in "traction control light" and clicked on the SC400/300 section, you would get over 60 threads on the subject. I would advise doing a search before you post a thread asking a question that has been asked and answered already. Good luck finding the problem.
Thank you. Tammy, it was the brake fluid level. I did some research on it and that had to be the only option. I also did my brakes not too long ago so it had to be the problem.
Thanx a lot guys.
Thanx a lot guys.
