exhaust intsall help
Anyone got tips on how to take the 2 bolts after the primary cat off, they seem to have melted or i guess heated weld on the darn flange i started to dremel the bolt side that face the rear of the car but noticed that there melted or heat welded on both sides and i cant fit a dremel on the side that faces the front side (nut).
Anyone got some tips beside taking it to a shop lol.
thanks
thanks
If you already started to work at it with the dremmel then I suggest you keep going until it comes off. You have be be a savage with it until it pops right off. If you damage the flange and you can no longer fit a bolt through there then you can always take it to a shop.
its not striped its like weld on to the flange lol guess cause its soo old. I just dropped the whole thing im try to decide how to go about serperating the flanges. cause they seem to be melt together to.
was thinking about using a reciprocating saw but don know if that will work.
