HELP! What does this connector go to? (1JZ swap)
Hey guys, I made a post like this a while back but nobody really knew what my cut wiring harness went to. Now I made some progress, and hopefully with your help I can get my car running
Anyway, my ignitor harness was cut. (4 connectors... a 12 pin, a 10 pin, a 4 pin, and a 2 pin) The 12 pin goes to the ignitor, along with the 4 pin... leaving a 10 pin connector and a 2 pin connector. Now, I looked on my friend's 1JZ supra, and his 2 wire connector just seems to go to a small black box that gets grounded to the chasis. This leaves only the 10 pin connector.
It seems the 10 pin connector goes through the ignitor bracket, but I have no idea what it goes to after that?? Here is a pic of an ignitor, with what seems to be the gray 10 pin connector. Do you guys have this, and if so can you confirm it is a 10 pin, and maybe even tell me what it goes to?
![](https://www.clublexus.com/gallery/data/500/scan.jpg)
My car misses being driven, please help!!!!!!!
![](https://www.clublexus.com/gallery/data/500/medium/Picture_0253.jpg)
my ignitor has that grey plug on it. those three plugs on the ignitor come off the same part of the harness. not sure if its 10 pin...i can look tomorrow, its dark and rainy outside now
That's definately the only 1JZ / 2JZ Turbo ignitor... the reason it may look different is the bracket that it is mounted on, and that connector. Looks like it's possible to have that connector without having it clipped into the bracket, so some of the 1JZ guys may have it setup differently... of the two ignitors I have, neither have brackets.
blksc300mt- If you could look for me tomorrow or whenever that would be great, thanks a lot
Originally Posted by got_trd
i dont see a 10 pin connector anywhere near my ignitor harness... just the 3 plugs on the ignitor, and the 2 plugs that go to the fuse box...
12pin, 4pin, and 2pin on the ignitor.... on the same loom is the wires for the diagnosis box which attaches to the intake manifold. also on that loom are the 2 plugs that run up to the fuse box..
