Whos the fastest on the stock NA auto?
Since you've been searching so much I'm sure you already know about this but if you are willing to drop 2 grand then why not go with the boostlogic NA auto build transmission. It seems like one of the safer bets out there.
ill give a little input
im running a stock auto tranny.....
with a shift kit, tranny cooler, mobil 1 synthetic, and a modified stock TC
i have around 400 rwhp on a stock motor with head gasket, 60-1 turbo, VPC, 440 inj, FMIC,and run 15psi on pump gas.....
it is my daily driver although i dont push it hard at all....i know the stock tranny is suspect so i take it easy most of the time...if i run it hard throug the gears i give it time to cool back down....usaly i never run it through more than 2 gears at a time.......
it is tempting as **** to run around boosting constantly...but i know what will happen if i do
i have a stock 1jz auto here in the garage as a spare....im told it will bolt up...i dont know if it works like stock or not....like if electronics are diffferent?
id definitly like to know
Jeff
Jeff
