A/C leaking when not on?
ok heres something wierd. I came home today and put some cardboard under the motor. Now i di not use the A/C at all today. I came back after 3 hrs, and there is a leak on the passenger side, but it doesnt look like oil or coolant. Looks like water? any one have any thoughts?
No Sir, I Don't Like It
I was under the impression that what you use for the AC is a gas, not liquid. However when you do run the AC you get condensation that drips, but you ruled that out by saying you didnt use the AC. Buy a leak kit to see if your AC is leaking that should help you with this problem, if its not leaking, its not the AC.
bcorey
05-28-13 09:17 PM
phoenixm3
09-13-03 07:10 PM
