Will a supra koyo fit the SC3 5speed with no mods?.
Ummm... although you have increased the cooling capacity, I don't think you'll notice a difference in the needle unless you were overheating in the first place or you get a colder thermostat. The thermostat won't allow coolant to flow until it reaches a certain temp.
Greddy type "S" fits nice and snug. The OEM cap seems to work, but I wasn't satisfied with it's fitment. Didn't want to take any chances so I picked up a Greddy cap. Also heard that Blitz caps work, but I'm not positive.
well the answer to this thread is definately NO! you definately have to do mods to get a supra tt koyo radiator to fit into a sc300. i finally installed mine. took some time and i had to custom make rubber mounts, trim the fan shroud with a dremmel, and make a plastic bracket to still use the sc300 shroud. i'll have to do a write up or something later cause i got pictures. oh and i ended up going with a arc cap. fits perfect.
supra koyorad into a sc300 5speed. my write up can be found here... http://www.clubna-t.com/forums/showthread.php?p=18325
