Whinning sound when revved!!
still did not fix my squeek yet i think it is the crank pulley now. i am glad i did not spend the 315 bucks to change the damn ps. thanks i need to change the ditributor o ring too. it is cheap i kept putting it off. i don't want to have to spend more $ for an alenator too
i was checking my car today running it to see if the squeek was coming from the crank for sure. cause it first sounded like it was coming from the power steering. i sprayed some belt dressing to try to quite the squeek it worked so i took it for a ride and my gauges went out and the car started to sputter. i made it back to my house and checked the car running barley and it has low voltage running bad alternator. what a head ach i had my acessory belt off and i spun the alternator it spun fine and the squeek came from the crank. i actually flushed my ps thinking it was that but finally i have the same issue as you bad alternator. again thanks i am glad i just did not start buying stuff to figure it out.
hi guys.
would a vaccum leak cause this noise to come on too?
mine happens all the time, except the noise slowly dies out when i step on the gas, and comes back to the whinning noise when i let go of the throttle.
and also, how much would it be to get a new headgasket put on?
i'm losing coolant too.
it could just be bad coolant.
Pilot bearing
Transmission input shaft bearings
The transmission and bell housing will need to be removed to determine which or the combination of the three.
Insure the clutch free play has not been eliminated by air in the hydraulic lines. If so, the throwout bearing will constantly run on the pressure plate release fingers, causing it's failure.
gabzor
09-15-12 07:02 AM
orozco543
07-30-12 09:10 PM
Shaffer
02-12-04 09:26 AM
