Value of SC with GTE swap vs. NA-T
compression on a stock GTE = 8.5:1
stock GE = 10:1
The GE and GTE share the same crank, rods, and piston MATERIAL (shaped slightly different). The compression between the 2 lies within the headgasket. Stock GTE HG = 1.6mm versys the .2mm of a GE HG.
just to clear up some information here....
stock GE = 10:1
Originally Posted by jgscott
There is always long term value in a car with the original motor and serials #'s matching. Not short term but long term, the matiching original matching block with serial #'s holds more value down the road.
For what people are looking to do with these vehicles the matching numbers simply don't mean much. Even the most cobbled-together NA-T kit can catch more cash than an original model! It may be wholly inappropriate but it still happens every week. Buyers are looking at numbers but they aren't stamped on engine blocks.
Cheers,
Originally Posted by RS3
For a mass produced car like the SC300 I would wager to say that a sorted GTE conversion (documented, etc) will carry more long term value than a NA-T equipped car. It will get even more than a nicely pampered factory original car (the exception being rare finds with ultra-low miles that catch the eye of those discerning few willing to pay significant premiums to have the cleanest examples in their stable). Were these cars being purchased by collectors perhaps the matching numbers might have more value. Even the most cherished are being driven fairly regularly; these just aren't the cars that are being tucked away in bubbles to preserve their all-original numbers-matching condition. Of course, if it's really a concern you could always install a non-stock motor (be it NA-T or GTE) and retain the original pieces for resale.
Cheers,
Cheers,
" Value " is a relative term.
I personally think it doesn't matter whether you have a GTE or an NA-T. I think what people are really looking for is a manual transmission swap or a manual transmission. If the car had a Getrag, I believe it will add more value to the setup than a whole motor swap!
Originally Posted by ummagawd
ehhh fack it.... i'm going NA-T... i'm never selling my SC
Originally Posted by jpvarghese
Reason's Supras sell for more is because of the limited quantity not because of mods. SC's are everywhere.
Where are SC sales figures viewable?
Cheers,
For a period of 5 years; 11k isn't much. Here's a breakdown:
Supra TT hardtop 6-speed: 326
Supra TT targa 6-speed: 3712
Supra TT auto targa: 2939
Total 6-speed TT's: 4038
Total TT Supras: 6977
Total N/A Supras: 4262
Total Supras PERIOD: 11,239
Let's look at the competitors in the 90's in the U.S.:
Total 3000GT's PERIOD '91-'99: 79,536
Total NSX's PERIOD '92-98': 7421 (couldn't find data for the remaining years)
Total 300ZX's PERIOD '90-'96: 89,156
Total RX7's PERIOD '93-'95: 13,879
Your better off going w/ 1jz swap if your on a budget. Slapping a turbo kit on a GE motor are known to have reliability problems every now and then., since the motor did not come turbocharged from the factory. A gte swap is reliable because its a direct swap and the majority of it is plug and play.
I used to think so also... but with the 8 months I've spent researching all this (going NA-t vs. GTE swap)... I think the reliability factor is marginal.
I mean yes it's easier to feel more comfortable knowing the motor came stock with turbos... but the 2JZ series motors in particular were all carved from the same foundation. A properly done up NA-T (headgasket upgrade and all on a healthy motor) would be just as reliable at sub 450hp levels.
Then again... to each their own.
Anybody else thinking about aesthetics when taking these options in to consideration? The NA-T setup makes for an awfully cluttered engine bay.
Cheers,
This is a very good point.
Cheers,
Cheers,
oh gawd yes.... i've only seen one NA-T engine bay that didn't look so bad... didn't look bad at all. But I think it was all the bling that offset the clutteredness.
Anyways... i'd be doing a GTE-style custom manifold anyways..... but yes I think to some the aesthetics of a GTE swap is much more appealing and holds some value.
