HKS FCD & Greddy Speed Cut defencer
Old 08-08-06, 07:39 PM
V300Altus
V300Altus's Avatar
Default HKS FCD & Greddy Speed Cut defencer
Have 1JZ installed on SC3. Does anyone have pictures of ecu pins and directions for the install of both HKS FCD and Greddy Speed Cut Defencer. Tried the search button, nothing solid. Thank you.
Old 08-10-06, 04:48 PM
V300Altus
V300Altus's Avatar
Bump, Any ideas, Anyone,
Old 10-11-06, 11:21 AM
jgdynamics
jgdynamics's Avatar
here you go, not sure if this thread is old or not...
Old 06-04-07, 03:50 PM
konspec
konspec's Avatar
is this any different for the auto ecu????? tring to install asap
Old 06-04-07, 03:57 PM
konspec
konspec's Avatar
greddy's instruction book says use the ground on the right, speed input on the right, and the battery out.. but it's for a manual ecu
Old 06-04-07, 05:47 PM
SnShne1jz
SnShne1jz's Avatar
I used that map and it worked fine for me but i also have a 5spd ecu
Old 06-04-07, 07:42 PM
got_trd
got_trd's Avatar
the last line in my sig is not a lie..............
check out this link
https://www.clublexus.com/forums/sho...ight=speed+cut
Old 02-19-13, 12:13 PM
kez
kez's Avatar
Bumping this thread from the grave.
I need conformation on this fellas I need to buckle down and get this car done for spring
Ohh yeah I have 5speed soarer ecu
Old 02-19-13, 01:40 PM
scmaluco
scmaluco's Avatar
worked for me . and i have a Automatic :/
go for it.. i used that to install my speed cut and safc
Old 02-19-13, 05:14 PM
sayayin
sayayin's Avatar
I remember to have speed cut, what I did was cut a pink wire on the wires going to the ecu, I have 1jz with 5 speed I will try to look which one so you can try it.
Old 02-20-13, 03:16 AM
kez
kez's Avatar
Ok good PICS will help big time
Anyone have same setup with pics
Old 04-19-13, 05:52 PM
Toyboxx
Toyboxx's Avatar
Sorry to bump the old thread, I'm about to pull the trigger on a Greddy Speed Cut Defender, and would like some better pics or clarification please. Thanks guys!
Old 04-19-13, 05:56 PM
kez
kez's Avatar
I actually haven't even got around to do this yet if you do before me post some pics up of detailed DIY
Old 04-19-13, 06:33 PM
Toyboxx
Toyboxx's Avatar
Will do. I have read that you could techinally cut the pink wire on the body plug, and that will eliminate the speed cut, but will result in a CEL..
Thinking about doing this till my SCD gets shipped and delivered.
Old 04-19-13, 07:12 PM
kez
kez's Avatar
Yeah I did see that in the above post I haven't gotten around to it since I bought a 3.92 diff and I want to see if speed cut happens as quick as the 4.27
lfrers
SC400 / 300 Classifieds
13
03-09-11 11:57 AM
sayayin
SC- 1st Gen (1992-2000)
10-04-10 07:00 AM
thegadget
12
12-23-07 09:27 PM
zazzn
GS - 1st Gen (1993-1997)
07-24-07 07:49 PM
James1830
01-24-06 02:34 PM
Quick Reply: HKS FCD & Greddy Speed Cut defencer
