Supra TT Motor Into SC300?
Who here has done this swap? I am VERY interested in performing this swap, and I would like to know what is involved, what costs are associated, parts, etc...? How about some stories from those of you who have done this? Thanks!!!!!
Basically, you pretty much need a front clip from a mkiv, tranny, ecu, rear-end, and many many little things. The electronics are by far the biggest problem, not to mention, building a custom tach, fuel and a few other things.
Even if you did the swap, you would only get 320 bhp at th crank, if you wan to achive bpu or even bpu+ status, it will run you an easy 25-30K. Not including the price of the lexus, or down time.
Just check out power house racing in texas.
turbo TT conversion
You CAN do this! I installed a twin turbo engine in my SC300. Using the existing 5-sp Lexus trans. Took 12 months, lots of heartache, but did the whole thing myself in my garage. I've documented the entire process on my website, and offer a manual describing the process in detail:
www.fly-hawaii.com/lexus
its alot easier to just turbocharge you motor...you motor with the right set up can hold 600rwhp with stock pistons rods..crank and head.........Toyomoto offers a wide variety of options and has EXCELLENT quality products.....no need to ditch a perfectly good motor.......tt motor is also very good but cost to value is alot higher....Jeff
305-599-3050=Toyomoto
9secCivic
Performance & Maintenance
38
12-24-07 04:39 AM
