reset ecu on 1jz, car dies every time i stop
I reset my ecu and now every time i come to a stop my car will die. If the a/c is on it will still idle rough but will not turn off. I understand that the ecu is "re-learning" but i dont see a reason why it should die every time i stop?
Try resetting again, but let it idle a few minutes before you drive. Also
no boosting for the 1st 5 minutes or so of driving.
If that doesn't work try cleaning out the throttle body. If you have TRAC
control you'll have to remove the throttle body to access the rear plate.
I spray carb. cleaner onto a small brass brush to remove the build up.
DO NOT spray carb. cleaner on/in the throttle body directly, it will
damage the sensors.
damage the sensors.
