HELP!! Fan belt snapped!
Old 08-20-06, 07:34 PM
JIC JZZ31
JIC JZZ31's Avatar
Default HELP!! Fan belt snapped!
Earlier today, I tried to start my car and initially the car wasn't starting. So I popped the hood and had my brother try to start it up again. The engine did start with a very low RPM, but just as I was looking at the fan belt, it snapped
Luckily my car is still at home safe in the garage but my question is, can I still drive this car to a shop?? What exactly is the fan belt connected to? I'm pretty sure it is also connected to the AC compressor, but is there anything vital? Thanks for the help guys.
Old 08-20-06, 07:45 PM
1sxyrxy
1sxyrxy's Avatar
u can drive it but not to far in much traffic cuz it will over heat. just drive it to a close shop it should be fine
Old 08-20-06, 10:02 PM
audi2nr
audi2nr's Avatar
your alternator will not charge the battery. the car will run like crap or not run at all w/o electricity.
Old 08-21-06, 06:35 AM
IS0LD0UT
IS0LD0UT's Avatar
get it towed.
Old 08-22-06, 01:39 AM
5spdSC300
5spdSC300's Avatar
Go to your local auto parts store and pick up a new serpentine belt. It should be under $50. Look under you hood and you should see a diagram of how the belt should go. Use a wrench as shown in the pic below to loosen the tensioner so you can get the belt over it. Let us know how it goes.
Old 08-22-06, 10:22 AM
Trashed
Trashed's Avatar
new belt is very easy to install. do it yourself! there are no bolts to do and if u use this above u will have no problem
Old 08-22-06, 10:34 PM
1sxyrxy
1sxyrxy's Avatar
car runs exactly the same without the alt
Old 08-22-06, 11:09 PM
JIC JZZ31
JIC JZZ31's Avatar
Thanks for the help guys and to 5spdSC300O for providing the diagram. I just bought the Goodyear serpentine belt from Kragen for $30 and I'm going to put it on tomorrow.
Actually, my alternator went out before and what happened was that basically nothing worked inside my car like the radio, horn, power steering, ac. The car was drivable, but it was idling VERY low. Once I got that replaced, everything was ok
wcoastls
25
05-19-14 07:37 PM
IBOO57
13
06-07-13 08:12 PM
96amc
09-06-10 05:07 PM
blkstealthpaid4
18
12-28-08 06:20 AM
DryBlaze
09-25-07 10:10 AM
Quick Reply: HELP!! Fan belt snapped!
