Oh oh... always something
The other day I disengaged the Traction Control by pressing the button and the Check Engine light turned on at the same time the Traction Off light turned on. When I pressed the button again to to re engage the Traction, both lights stayed on and wont go off even if I turn off and restart the vehicle. While this all happened, the car ran fine so Im just hoping I blew a fuse or something. Anybody else experience this?
Thanks in advance for the posts... you guys have been very helpful
E
E
Is that a reset or something? Will the Check Engine light go off too or it this an isolated problem?
Just trying to avoid spending a $$ grand $$ at Lexus... Always seems to add up to about that much when I take it in.
bad cats throw off the O2 sensors....and the check engine light comes on. I ignored my check engine light for a year, because it come on and went off...so I thought it always does that. Now I have to replace my cats GOOD LUCK
the trac light usually comes on when the check engine light comes on, and i don't know why....... but my car had the same problem. once you get the sensor or cat replaced, it will both turn off. to save $ you can try to clean the sensors, and or mufflers (this is what my brother did, and it worked) increaseing the airflow helps i guess. hope you find a way!
Today I finally had the chance to try the above advise and it worked... What did this actually do? Was it a re-set or something????
blkis_250
05-23-20 01:53 AM
Stuno1
IS F (2008-2014)
17
09-05-14 06:57 PM
