a/c gets much colder when car is moving
Old 03-31-08, 08:18 AM
NiceSC400
NiceSC400's Avatar
I know that this thread is old as hell, but my car does the same thing. What I noticed is that when the car comes to a stop or idles the A/C compressor stops and if you rev it up just a little the compressor kicks in again.
Anyone has this same problem? What is causing it? Idle sensor problem?
Old 03-31-08, 12:56 PM
tcrow31
tcrow31's Avatar
Check your freon sounds like your a bit low.
Old 03-31-08, 01:11 PM
Ghostly E
Ghostly E's Avatar
I have the same problem where the clutch will disengage on the compressor could my compressor be bad?
also my freon level is good
Old 03-31-08, 01:26 PM
19psi
19psi's Avatar
if your compressor is cutting off, either your freon is low (have it checked, you have no way of knowing without having it evacuated and weighed), or you have a pressure switch going bad.
Old 03-31-08, 02:00 PM
Ghostly E
Ghostly E's Avatar
I replaced the pressure switch and the system was refilled and its completely full now it will work for like 10 mins and then hot air for the rest of the time
Old 03-31-08, 02:51 PM
tcrow31
tcrow31's Avatar
I would have guessed pressure switch or freon level. Since you replaced those it could be a bad clutch, compressor or something with the electrical going to the pressure cycling switch.
Old 03-31-08, 04:17 PM
19psi
19psi's Avatar
in that case, y ou'll need to take it somewhere and have it diag'd. a/c is really hard to diag online without guages and visual inspection and test equipment.
garylbarr
RX - 4th Gen (2016-2022)
14
04-05-17 01:15 PM
Doublebase
01-23-17 01:57 PM
sprtdsgnGS
05-07-15 02:22 PM
Ice350
Florida Lexus Club
37
01-10-10 02:06 AM
Xeeeeeem
GS - 1st Gen (1993-1997)
12-02-06 10:30 AM
Quick Reply: a/c gets much colder when car is moving
