1jz gte question?
1jz gte question?
hey i have a 95 sc300 lexus with a 1jz gte motor swap, my ? is where would i find a good upgraded ecu, i have a governer still and it cuts out at 120? is that normal? also, i have a safc but not installed? any advice on what single turbo upgrade i should do if my goal is 450-500rwhp? and what inj.........im thinking about the pt51 turbo from precision, and 550 inj. but i dont know about the safc and the ecu(map). let me know your knowledge im new to this supra motor thing!
ok two things first. this should be in the engine trany ect. forum and try searching because all the info is there. but i feel generous today
so here goes.
1) where would i find a good upgraded ecu, i have a governer still and it cuts out at 120?is that normal?yes its normal i believe blitz has a speed cut defencer that will eliminate that
2)i have a safc but not installed?search for 1jz wireing diagrams. this might help http://www.jzgte.com/images/tech/1jzecu_diagram.gif
3) any advice on what single turbo upgrade i should do if my goal is 450-500rwhp? and what inj.........im thinking about the pt51 turbo from precision, and 550 inj. but i dont know about the safc and the ecu(map). let me know your knowledge im new to this supra motor thing!sorry im no help here so search i know the info is out there, try the 1jz section on SF
so here goes.
