where go that cable (1jz )
I done 1jz swap in place v8 engine.
body plugs phisicaly are plug in but not eletically. try find some cables...
there is one of them
before fuse box in engine compartment there is two black plugs. one is 8 wire
and another is 3 wires black plug
and that black 3 wire plug with thick wires is my question
on soarer engine harnes side in midlle that plug is white cable.
on photo it is in yellow shrinking isolation. where that white cable go to engine harnes. what it is on its end?
at bottom picture you can see that white cable it is cut of fron that yellow shrinking cable
that plug is named probably CA1 in soarer service manual.
thanks
Jerry
thanks
Jerry
hey guys
nobody have soarer and soarer wire schematic?![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
need that
as in picture below
in pin 2 there is white wire on soarer engine side harness
that plug (black big one) is under hood between battery and fuse box
Jerry
need that
as in picture below
Jerry
