All 1jzers q?
Old 08-26-06, 06:23 PM
lpolo69
lpolo69's Avatar
Default All 1jzers q?
What do you guys do for o2 sensor? Do you use the stock ge one and wire it in or what? Or not use one at all?
Old 08-26-06, 11:35 PM
JJG2005
JJG2005's Avatar
I used stock 1JZ sensors... mine came with the engine set.
Old 08-27-06, 10:17 AM
philauldridge
philauldridge's Avatar
You MUST have at least the one O2 sensor... that is what communicates air/fuel ratio to the ECU so it can adjust fuel output accordingly. Any standard sensor should work
Old 08-27-06, 10:19 AM
dubstar
dubstar's Avatar
i used the one that came with the motor ...buy a front clip. the best way to go
Old 08-27-06, 10:45 AM
Durrr
Durrr's Avatar
just find how many wires the O2 sensor has, get a same number of wires O2 sensor, cut and splice. You're done
Old 08-27-06, 11:00 AM
JTJerryls400
JTJerryls400's Avatar
1jz have 3-wire oxy sensor. my have one sensor in place 4 in v8 I throwed away. That is simpicity.
Old 08-27-06, 12:51 PM
Rising_Sun
Rising_Sun's Avatar
91 turbo MKIII supra O2 FTW
daddystop
IS - 1st Gen (2001-2005)
03-20-19 06:51 AM
SMUChris
12-17-12 03:50 AM
martshap
07-08-09 04:26 PM
shern
02-24-09 07:45 PM
hugo2648
RX - 1st Gen (1999-2003)
07-23-07 07:17 AM
Quick Reply: All 1jzers q?
