MA70 1J into SC
lol, if you guys really want them, I can help you order them when I order the engine mounts. (in about a week or so) They're not going to be something that just plugs in though. Even I don't want to mess with the hassle of installing one.
i have a soarer harness / computer that i will trade for your supra harness / computer.
Im trying to stick a 1jz in my mk3 supra and this soarer harness is not going to work for me without major headaches!
Let me get back to you on this as my engine just came in and I'm trying to figure out what needs to be done. If it turns out it's less headache for both of us to swap harnesses, I'm down
I think you were closer the first time. I think a MKIII Supra with 1jz is called JZA70 and the 7mgte are called MA70. In the U.S. we only got the 7M Supra so all of ours are MA70. With Toyota chassis codes it's engine family then body style. For example SC300/Soarer 3.0GT are JZZ31, 1jz Soarer are JZZ30, and SC400/Soarer 4.0GT are UZZ30 or UZZ32(I think) if they are air suspension.
lol.. i'm down for a trd push start button group buy
the F-Con won't be an issue, but you will need a 1j soarer harness and re-wire the f-con into it... did it come with the MA70 transmission? if so, theres a bracket that changes the shifter location, and I read about it on here. You would definately need to get that bracket if you wished to use the R154 (which I would highly recommend).
Curated Content Editor
SC- 1st Gen (1992-2000)
05-05-18 12:02 AM
LexFather
02-12-09 07:38 AM
