toyomoto manifold and clears distributor?
Old 09-11-06, 02:15 PM
chitwnsazn
chitwnsazn's Avatar
Default toyomoto manifold and clears distributor?
So I'm considering buying a brand new toyomoto tubular manifold off someone and it's not a custom made unit either. He says it will allow a T61 with a 4 inch inlet to clear the dizzy but I'm not sure if toyomoto ever produced manifolds that would clear it. Does anyone know if toyomoto has updated their design? Here's a picture for reference however the one I'm getting has a flange for a tial 44mm wastegate.
Charles
Old 09-11-06, 07:59 PM
lfrers
lfrers's Avatar
Default toyomoto
I have a toyomoto manifold running a TD06 25G on my SC300. My turbo is kind of big.
if that helps.
I think they are out of florida
Old 09-12-06, 03:43 AM
chitwnsazn
chitwnsazn's Avatar
well did you have to modify the manifold?
Old 09-12-06, 07:58 AM
lfrers
lfrers's Avatar
Nope. However mine was made in around 2000. So it's 6 years old. I can send a pic later if you want.
Old 09-12-06, 03:35 PM
chitwnsazn
chitwnsazn's Avatar
that would be great
thanks
charles
Old 09-12-06, 03:46 PM
chitwnsazn
chitwnsazn's Avatar
but your car is distributorless isn't it?
Old 09-12-06, 04:10 PM
lfrers
lfrers's Avatar
No it's a 97. Woops. I meant to say the car is a 97. It was turbo'd originally in 2000. I swapped the turbo kit to my latest 97 SC. But the manifold is from 2000. The mad dog turbo was bought and installed a few months ago.
I realize now when I was adding the thermotek heat shielding that the pipes on my manifold are much shorter than yours. My turbo sits low in the cavity.
Old 09-13-06, 10:44 AM
lfrers
lfrers's Avatar
heres my setup when it was installed on my first 97. My current setup is identical except the guys who did the turbo swap fabricated a straight inlet pipe to the turbo and replaced the other pipe to the throttlebody inlet. My old setup used to use the two additional injectors. But here you see the Toyomoto Manifold. Well kind of. It's a little cluttered.
Old 09-13-06, 02:48 PM
chitwnsazn
chitwnsazn's Avatar
i think you have their older log style manifold and not the equal length tubular manifold. Nice setup you got though thanks for the pics
Old 09-13-06, 05:32 PM
nasc300
nasc300's Avatar
It will not clear the dizzy
SC YAA
SC- 1st Gen (1992-2000)
06-24-11 12:05 PM
Trbobucket
12-09-08 03:17 PM
J J
13
11-30-05 11:31 AM
qtb33
19
03-06-05 08:50 AM
Quick Reply: toyomoto manifold and clears distributor?
