Clutch or Trans?
Clutch or Trans?
Well ive searched like a **** and had a question I was hoping someone might be able to shed some light on. I got a SC300 with a Getrag 6spd. When its in neutral its got a clunky noise going on. When in gear It quiets down completely. 1st and 2nd are getting a little dificult to get into. Throwout bearing in clutch? or does it sound like a tranny prob? I'm kind of thinking clutch.
BTW Took the SC to Vegas and saw Guns N Roses at the Joint. It Kicked ****!
Thanks. Yea that’s exactly what it does. The throw out bearing was replaced last in 2005. The drive train was swapped in 2006 from another car to this one. All the receipt for the clutch says is RTS carbon claw clutch. All together it was expensive. Listed were pressure plate, flywheel assy, pilot bearing, TO baring, Bolts, seals and a bunch of other crap. Itemized it came out to be over a $1,000 but the bearing shows only $65. Do you think the throw out bearing will be a generic enough part that I can just go to Pep Boys or a tranny shop and ask to have one put in.? I don’t have enough free time to do it myself right now.
If the clutch arm was not adjusted to pull the throw out bearing from the pressure plate, the throw out bearing may be engaging the pressure plate consistently. Air in the hydraulic clutch system may also be a cause.
This is referred to as "clutch free play". Most clutches have an inch or so of pedal free play before the throw out just presses the pressure plate release tangs.
Without the correct amount of free play, the bearing overheats and drains it's grease ... then burns the internal *****, rusts and it starts to growl.
Did the conversion include new master and slave clutch cylinders? A internally leaking cylinder may have thrown out the clutch adjustment.
No it did not. I will check to see if they may be leaking. But I did not want to go to the shop if they would not be able to work on an aftermarket clutch like this. If Throw Out bearings are pretty generic then I will take it in to be replaced and have the Clutch slave cylenders checked at the same time.
Thanks for the info.
